I have MSI A320M PRO-VD PLUS motherboard and i want to insall watercooler Cooler Master ML240L RGB. I have 1 problem i don't have pump/cpu-out header. Where i should plug pump to? I thought, idk if i should, but i want to use adapter sata power to 4pin to connect pump and use cpu-fan header for fans on radiator? Should i do that? Is it safe?
