ShameerM90
As the tile says, I have kept experimenting. Following is the list of apps which were installed { Pi -Rate- ED).
Photoshop 2019,
Rhino 5.
I could list others too but i have used them for many years in past but no issues to date. Others which i had doubts on are,
Illustrator 2019,
inDesign 2019.
So I have formatted and reinstalled my windows many times. I thought it was windows versions. So I changed, tried, 1903, 1909, 2004 Same results.
With each subsequent installs of windows I uninstall 1 previous software to rule out if it was causing issue. Right now I am only left with photoshop but that is a software i need the most. I also have it installed on other laptops but they have shown no issues.
P.s. Ever Since i Installed it on other laptops {Photoshop} I have had this issues 3 times. So i doubt it is that.
Now With windows security out, Bitdefender total security out, this time I thought I would Reinstall the antivirus and scan. Apparently that something is blocking me from doing it. It shows not unusual notification or error. It just closes.
Things I have tried to no use.
Restore points. { Nope These are deleted too}
reset keeping file {does not help}
Anyone has an idea what it can be? How is the thing still there on pc if i format the drive?
p.s. I have 2 drive. 120gb ssd (OS and no softwares), 1TB HDD partitioned in 2 500gb drives. (Data and Programs)
I have only formatted the 118 gb partitioned of ssd where os was installed.
I tired malware bytes before posting this. Here are the results attached to this thread.
Can we track where they are coming from and how?
Observations So far.
It seems to strike a few weeks after a fresh install.
cant install any antivirus after it happens,
windows restore also stops working,
it does not seem like it has to do with software i installed {because of deductive testing I did}
Does not seem to transfer itself over usb drives.
Photoshop 2019,
Rhino 5.
Illustrator 2019,
inDesign 2019.
