That's interesting. They fixed the speed on the search bar function, I haven't really used the menu anymore aside from just using it as an item to populate the search results with. On w10 sometimes it took 5-10 seconds just sitting there spinning, which is frustrating when you want a query fasterI had to create a separate folder and place shortcuts to all my games in there and then pin that folder to the start menu...which then opens it on the desktop instead of in the start menu. If I didn't hate clutter on my desktop so much, I would have just placed the folder there.
lol yes. You kind of have to find unique or undervalued products to be cost effective. People paying $2500 for cards is pretty crazy however.The entire market is very demotivating right now.
Funny enough... if you installed Microsoft's PowerToys utility (which honestly they should just add those damn features into the base OS), they have the PowerToys Runs tool that queries instantaneously on apps and folders you're searching for.That's interesting. They fixed the speed on the search bar function, I haven't really used the menu anymore aside from just using it as an item to populate the search results with. On w10 sometimes it took 5-10 seconds just sitting there spinning, which is frustrating when you want a query faster
Lame. I had a similar experience, although I got everything where I wanted it and then Rocket League wouldn't launch like, -at all-. So I revertedAfter mounting frustrations with Windows 11, I rolled back my system to Windows 10.
My guess is that the 1700 doesn't have TPM baked into the chip itself. You'll have to get a separate TPM 2.0 module to plug into the motherboard and enable it in the BIOS.I downloaded the compatability checker tool, expecting a TPM failure. Which I got. But I guess Ryzen 1st gen isn't supported by W11 at all.
Alright Microsoft, that's cool. My not even 5 year old CPU is "unsupported" while we're in the depths of the greatest PC hardware shortage probably ever.
Cool cool cool.
Nope they flat out said Ryzen 1st gen isn't supported, regardless of TPM. It does look like you can technically get around it by wiping and installing fresh, but upgrade path isn't an option. Definitely just an arbitrary requirement.My guess is that the 1700 doesn't have TPM baked into the chip itself. You'll have to get a separate TPM 2.0 module to plug into the motherboard and enable it in the BIOS.
					www.hardwaretimes.com
				"Sorry your old PC doesn't support our new operating system, have you considered buying a new one that does?If they can give me an actual hardware reason behind it, sure
				Instead of just saying I hate windows 10, why don't you say why you hate it. There are ways to make it look more like windows 7 with an actual start menu, quick launch.I hate Windows 10
Transferring personal data and bookmarks is pretty easy. Your local computer repair store can do it. If you signed into chrome or firefox and have sync enabled, then its just a matter of signing back into your specific account and the data will be there. Technically you should be able to do a fresh install of 11 on your computer and use the windows 10 key to activate it. However, you may need to do a special procedure to bypass the requirement. You can't bypass the requirement when upgrading from 10 to 11.I too, got the message that, "this P.C. doesn't currently meet the requirements to run windows 11" Does this mean that I will be needing to buy a new computer in 2025, when Microsoft will no longer support Windows 10 ? This is what happened last time, when I bought my present computer less than 5 years ago . It's not the cost of the computer that I mind but losing all the stuff in the old computer such as bookmarks , passwords etc. It's fine for people that know how to transfer everything over but I am not one of those people.
Did you run the PC Health Check program (can be downloaded via Microsoft's website)? That program goes into detail what specifically your device failed at to meet Windows 11 requirements.I too, got the message that, "this P.C. doesn't currently meet the requirements to run windows 11" Does this mean that I will be needing to buy a new computer in 2025, when Microsoft will no longer support Windows 10 ? This is what happened last time, when I bought my present computer less than 5 years ago . It's not the cost of the computer that I mind but losing all the stuff in the old computer such as bookmarks , passwords etc. It's fine for people that know how to transfer everything over but I am not one of those people.
It is telling me that "The processor isn't currently supported for Windows 11" This means that I will need to buy a new computer in four years time, right ?Did you run the PC Health Check program (can be downloaded via Microsoft's website)? That program goes into detail what specifically your device failed at to meet Windows 11 requirements.
Depending on what failed and what your PC spec's are, it could be as easy as clicking a button to enable a feature in the BIOS, or as bad as you need a new computer to make Windows 11 work.
