Hi,
someone has gifted me a old acer aspire switch sw3-013. When i got it there was Windows 10 64 bit installed. I wanted to install a different OS, but it won't work. So i came back to Windows 10, but now with 32 bit. I'm trying since yesterday to install the 64 bit version, but somehow i'm not able to do that...
I have downloaded the windows media creation tool and made a bootable usb stick. From the stick i can run the 32 bit version, but the 64 bit stucks. When i try the setup.exe from the x64 folder it says something like 'windows can't execute this program, contact systemadministrator'. The setup.exe from the x86 folder works fine.
When i try to run it at boot it says that the processor doesn't support 64 bit. Even if the system info says 32 bit os on a x64 processor.
I think it has a 32 bit bios, but a 64 bit processor or something like that...
Is there any possibility to install 64 bit again? I would really need it...
Thanks in advice,
dissi
Thanks in advice,
dissi
