How do I use my Wi-Fi dongle on my PC?
JohnJSal
Hi all. After being gone for a few days, I have returned to find that my internet is not working. I've tried power cycling the router, but it doesn't work. It makes me think it's a problem with the service itself.
Anyway, as a temporary fix I was going to use my old Wi-Fi USB stick that I used to use, but when I plug it in, all I hear is a little noise that indicates a device has been detected, but I don't see where I can access the device or connect to a Wi-Fi network with it.
What do I do? I don't recall having to install any software with it, and at any rate I don't have any software for it now. Am I missing a setting somewhere?
Thanks!
JohnJSal
What services are you using (e.g. for internet)
What USB stick.
We're not magic.
The stick is a LinkSys with a model number AE3000. The internet is my T-Mobile Hotspot.
I didn't think that mattered much because I figured they all worked basically the same way.
johnb35
Administrator
Look under network adapters in device manager and see what is listed. You should also see any entries that are still requiring a driver. If the linksys adapter has the driver installed already then just connect to your wifi.
Can you connect with a cable to verify the internet is working and not just a wifi issue?
JohnJSal
That was exactly the problem! Bypassing the router worked, so at least my PC has internet. To get a new router through my ISP would be $7 per month (the one I have now they supplied for free), so no thanks!
I'll just start searching for a router to buy myself. Much cheaper in the long run and probably better quality, too! Any suggestions are welcome! ;-)
Edit: I'm considering this one:
TP-Link AC1200 WiFi Router (Archer A54)​
Very similar to the one I have now.
