Avi-to-dvd
superfreak
thats what im using, i wanna convert my home movies to a dvd format so they can be playd in most todays dvd players....any of you use this program... also wich format would be better vcd, dvd, or svcd
easiest thing to do would be to convert them to vcd or svcd and get a dvd player that supports them (the majority do so you likely have a compatible one already), as far as converting to actual dvd format, you should search the forum, I think it's talked about every other week on average
