Master Mind
alright, i willl let you know how it went when i finished. umm in our old desktop we have a MX400, ive got riva tools or what ever its called and i was just wondering if this card can OC, if so do u know how?
The stock one is just fine. I have it and it keeps my card temps at 61C which is really good for that card.
ok, i want to know how far i can take this card without doing any damage to it, what is the highest speeds that you have seen my card reach? will it go to the X850XT PE??
so when i have reached the max that it will go what do i do? do i shut down the program and the setting will stay the same? do i have to redo it every time i start up if i dont go set OC?? im a lil confused
The stock cooler on those cards are fine, and unless you are volt modding it, the temps dont raise that much when you overclock.so thats all i have to do it will be all good?
also, iam lookin to get a new fan for the card, are the arctic coolers any good, and which one will fit my card? or is there a better cooler for overclocking?
so theres no point gettin the new cooler then?
