junwang0808
1GB PC3200 DDR HYNIX RAM pc memory sdram 1 gb
Up for auction is one stick of ddr 3200 ram. 400 mhz non-ecc. manufacturer is hynix (used in alot of pavilion HP computers). model # on the chips is hynix 506a hy5du12822bt-d43
and what brand of ram is good?
is this ram good for my computer?
and is a AMD processor faster or a INTEL processor faster?
for now the latest technology
AMD FX vs INTEL dual core 2
second ram is this good???????????????
184 pin Dimm (for desktop PCs, not for laptops) modules - 128x64
Less than 5 nanosecond
Backward compatible Works with PC3200 & PC2700 & PC2100
UNBUFFERED - NON ECC
6 LAYERS MODULE
128x4 Density chips
Certified Memory :
Certified for Optimum performance and Stability with New generation of AMD/Intel Processor Based Motherboards.
Guaranteed to work with Compatible Chipsets - List provided Below
DDR DIMMs that are fully compliant with the newly released JEDEC specification and reference design.
We test our memory for compatibility with all major system platforms.
Our certified memory is fully compliant with motherboards from all the industry leaders with DDR Industry standard.
Careful memory qualification done to help eliminate the uncertainty of the interactions between different components in a given computer system.
We have implemented a qualification procedure that is among the most stringent in the industry.
While such a strong qualification procedure cannot eliminate risk entirely, it offers the parts which are as robust as possible.
Return rates of less then 1% on Certified Modules makes this choice absolute.
Data Bus 64 Bits
Data Rate 200/266/333/400 Mbps
Bus Frequency 100/133/166/200 MHz
DRAM Frequency 100/133/166/200 MHz
Package Type TSOP-II
Densities 1GB
Voltage 2.5V
Prefetch Size 2 bits
Burst Length 2/4/8
CAS Latency 1.5, 2, 2.5
Write Latency 1T
6 LAYERS MODULE
128x4 Density chips
Certified Memory :
Data Bus 64 Bits
Densities 1GB
Voltage 2.5V
Burst Length 2/4/8
Write Latency 1T
