i have not read this but it looks plausible:
holl�w
XP password .: recovery :.
In case you forgot the Admin password
1, Put the XP install Disk to the CD drive & ReSTART your PC.
It should boot from the CD - if not - check on BIOS settings.
2, Start install. Soon the Setup screen will display.
There choose the "System repair" option.
--> "If one of the following XP installations is damaged,
Setup can try to repair it" Press R to start repair.
3, The standard installation process going on, but when you
see "installing devices" progress bar, press SHIFT + F10
4, A command console appears
so there you type : NUSRMGR.CPL and hit enter.
It will list up all the existing XP accounts on your PC.
5, Pick the user account you want to change password.
For PSW free log on, type : control userpasswords2
6, After these changes, continue and finish with Repairs.
Keep the XP product key at hand. ReSTART & Done.
yes i do have a link: http://www.kraytracker.com/forums/view_topic.php?topicid=1702
holl�w
