apj101 said:up the vcore, or vdimm (more likley vdimm given that prime95 error)
Well, he shouldn't have to raise the vCore more than 1.4v! I have my E6300 @ 3.4 Ghz @ 1.365v.
Have you tried raising the MCH voltage? As far as I know, doing that is crucial for overclocking the Allendales/Conroe on most motherboard out right now.
yep the northbrodge voltage is anpther important voltage in ocing the c2d, but it doesnt need much , just 0.5v would be enough
[ULKER];411516 said:Can find the Northbride chipset voltage. Any help?![]()
[ULKER];411574 said:In my BIOS there isn't any NB Vcore, Rambo your picture looks similar to mine but there isnt NB vcore![]()
there are many versions of the Asus P5B which do you have?
Apj means the BIOS version, not the motherboard version.
apj101 said:there are many versions of the Asus P5B which do you have?
[ULKER];411696 said:When i upgrade BIOS from 211 to 309, I can't hold the same OC at 2.6GHz, now im using 211 BIOS version.
When I temporaly upgraded BIOS to 309 I didn't noticed the NB Vcore.
Maybe there isn't NB Vcore manual select in Asus P5B![]()
P.S. Sorry for my language, Im not a real Canadian, Im Lithuanian. Just 2 weeks in Canada![]()
