34erd
Timna, Banias, Dothan, Yonah, Conroe, Allendale, and Merom are all P6 derivatives and very similar... Not convinced?No the core 2 chip is based on a completely new architecture, the core architecture. The core chips were the last ones based on the netburst architecture.
http://www.xbitlabs.com/articles/cpu/display/core2duo-preview_2.htmlX-bit labs said:Basing on the requirements we have just listed above, Intel engineers decided to give up NetBurst (which is actually not surprising at all) in favor of mobile processors microarchitecture, because these processors, developed from Pentium Pro, Pentium II and Pentium III boast relatively high performance level and are very economical in terms of power. However, the new Core microarchitecture has been significantly improved and enhanced in order to deliver higher performance, wider range of features and lower power consumption. As a result, it would be absolutely incorrect to claim that the prospective processors will be none other but adapted (for the new applications field) Pentium M.
EDIT: Also read the section titled "The Intel P8": http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2748
