Hi,
I bought a gigabyte P965 - DS3 motherboard and 2x 512MB ocz gold PC6400 800mhz. (wot a noob!)
So now i found out this stinkin ram dont work with my motherboard because the RAM default voltage is too high. Its 2.0v and the motherboard is set to 1.8v.
I read somewhere that if you buy some budget ram this will allow you to access the motherboard settings and change the voltage the ram recieves so it should then work.
so ive popped down to shitty pc world and got my 256mb of the shittest generic ddr2 ram uve ever seen!
can ne1 tell me if they rekon this will work
thx in advance
(im still waiting for the parts to arrive and i cant cancel the order!)
thx in advance
