conroe or amd
meanman
hi i am building a gaming pc and i want to know wich is best cpu i dont want
to overclock my choices of cpu are
intel core duo e6600 conroe 2.40 ghz
or the
AMD Athlon 64 X2 Dual Core 5000+ 2.60GHz
the only thing with the conroe thats confusing is which mobo is compatable
if the specs on the mobo say core duo ready will a conroe be compatable
also i dont feel comfy overclocking so i will run the cpu at stock speeds
WHAT?Go with amd.
I dont think you know what your saying.A core 2 duo E6400 smokes the fx62.
I have a core 2 duo e6600 overclocked to 2.88.I get almost better marks then the conroe extreme.
Conroe. It hands down beats the AMD line depending on which you get. I was JUST about to purchase an A64 5000+ when I was advised to go for the E6600 here - and now looking at the reviews, I'm glad I am!
or the
Definetly conroe, as to your question about motherboard. Just look on newegg for motherboards that are compatible with Core 2 duo, do not just buy any socket T motherboards and expect it to work.
Hay, how far can you OC e6300 to? I herd something like 3GHz......
Praetor said:
How much can I OC my system by?
This has gotta to be one of the most common questions people ask about OCing and the answer is nobody can tell you. This should be somewhat evident from the previous question (i.e., if two "identical" systems have different ceilings than how can anyone tell you how much you can OC by?). There are some general principles but nothing hard and fast
OC101
Go with Conroe, there is absolutely no doubt about it.
Also, Conroe is a name of a CPU, not a company like AMD ;)
Why do you say that? The E6300 has the best price per performance out of all the Allendale's/Conroe's...
Put it in the test then. Starting with super pi.. Show your cpu-z when you use super pi . then test it in 3dmark06 and see what cpu score you get.:D and compare that to conroe E6400:D
WTF was that????? I got hypnotized and watched that for like,.......an Hour! What a way to make a statement....
