NI_t3n_IChi_RYU
Ok this pc will be purely for gaming. Got about 700 pounds to spend just on the pc (no monitor, mice, keyboard is needed)
CPU
Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail
Motherboard
Asus P5B (Socket 775) PCI-Express DDR2 Motherboard
RAM
GeIL 1GB (2x512MB) PC5300 667MHz Value DDR2 Dual Channel Kit
(Is this enough to be playing the top games on?)
GPU
BFG GeForce 7600 GT OC 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
PSU
OCZ ModStream 450w ATX2.2 Power Supply
+3.3V(28A), +5V(45A), +12V(26A) (Is this enough power to be running the system on?)
Soundcard
Creative Sound Blaster Audigy SE 7.1 Sound Card - OEM
HDD
Western Digital Caviar SE16 250GB 2500KS SATA-II 16MB Cache - OEM
DVD Drive
LG GSA-H10NBAL 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM
Case
Thermaltake VB1000BNS Soprano SuperMidi Tower - Black
I put it all in a shopping basket on www.overclockers.co.uk to see how much it comes to:
Total : £670.27
Few questions tho. I mite think about putting in water cooling because i like my pc extremely quiet, ive heard this is quieter than fans etc. I will upgrade ram to 2gb wen i get enough money. Will it simply be a case of buying that exact same ram again and putting it into my pc? (so ill have 4 sticks of ram is this a problem)
Will upgrade gpu wen 7900's get cheaper just havent got the money atm to get 1. Will the psu be able to handle it. Im saying that i will upgrade these things but it wont be for a good 6 months so dont suggest just saving up more and getting them
Want to play BF 2142, HL2, CS:S, FEAR
Basically the top games.
Oh ye and i plan to overclock the cpu a lil bit. Also is there watercooling avaliable for the C2D chip yet?
Thx for your time and feedback in advance
CPU
Motherboard
RAM
GPU
- GeForce 7600 GT Core running at 580MHz
- 256MB GDDR3 Extreme Memory running at 1450MHz
- 12 Pixel Pipelines
PSU
Soundcard
- 7.1 surround output
- 24-bit/96kHz audio resolution
- 100dB signal to noise ratio
- EAX ADVANCED HD 3.0 support for gaming
- CMSS up-mixes stereo content to 7.1 surround
HDD
- Rotational Speed: 7,200 RPM
- Average Read Seek Time: 8.9 ms
DVD Drive
- DVD+R: 16x, DVD-R: 16x
- DVD+R DL: 8x, DVD-R DL: 4x
- DVD+RW: 8x, DVD-RW: 6x
- DVD-ROM Read: 16x
- DVD-RAM: 12x
- CD-R Write: 48x
- CD-RW Write 32x
- CD Read: 48x
- Access time: 145ms
- Buffer Size: 2MB
Case
Total : £670.27
