i have an asus a8n sli premium..... if you want to see the rest of my specs see: http://www.computerforum.com/59150-y-am-i-so-not-satisfied-all.html
any way i just installed this new mobo and pretty much all the hardware is new in the case but anyway it was up and running .... even though i was not satisfied with the preformance. so anywho i installed all the utilities that came with the mobo disk with the exception of the stuff that was junk. it came with a utility for updaying the bios, and it also sais to do this in the manual .... the verion that came with it was from 05.... the asus update sight had a version for 06 so i downloaded the file and used the utility to flash it and change the bios.... now it wont boot up, i get nothing on the screen it goes to power save. i called tech supp and they said then needed to send me a new bios chip..... they did overnight for 20 bucks . it still doesnt work. i called tech support and they told me to TAKE MY PC APART AND SEND THEM THE BOARD SO THEY CAN FIX IT YET NOONE KNOWS WHATS WRONG WITH IT AND IT MAY TAKE A FEW WEEKS? WTF GOOD GAME ASUS!
