If this thread is in the wrong forum please accept my apologies and move it.
I am planning to build a gaming machine for my son and me to use MS Flight Simulator X on. (It will also be used for other non violent sim and racing games that don't demand as much as FSX.) The current take on FSX is that it doesn't utilize dual core processors. Would it be a mistake to build a system using a single core processor that has a higher core speed than a dual core for the same cost? Or am I better served to build for the future with a dual/quad core processor and sacrifice core speed?
FSX appears to be a resource hog and needs serious horsepower to run even at mid to low detail levels.
I'm not sure which direction I should take.
Thanks for your advice,
Kevin
Kevin
