http://download.microsoft.com/ doesn't work for me for some reason... I can't download anything from Microsoft. Anyone know what the problem could be?
They took their damn time didn't they?!
This has been in Beta for ages!
You would check the security settings in IE and the firewall settings if you have one there to see if that is causing that problem to be seen. Another place to look is in the tools\options\security portion of Outlook Express. In IE it would be the "do not prompt for downloads" and "do not allows files attached to emails to be downloaded that may contain a virus" in the OE security settings.
Firefox, IE, Mac, Windows... doesn't matter. Any computer in my house won't connect there.
I can do everything on Microsoft until I have to use the download.microsoft.com server. I'm not one to have junk on my PC and I haven't had any problems with anything else at all... on any of my computers. This is really starting to bug me though, I can't download anything from microsoft.
Are you currently running any firewalls or have the security settings set to block downloads? Sometimes addon security tools can restrict normally overlooked items and consider the MS download pages as a "risk". If the settings are too high in Outlook Express with the "do not download files attached to emails that could be a virus" or others are up too high that could be one thing right there.
