twolves90
Hello. I have a concern with my CPU temp...
I got my new comp running for the first time last night!
It has:
ASUS P5B Deluxe Mobo /wifi
e6400 Intel Core 2 Duo
So here's the deal. I am using the stock heatsink/fan that came with the chip... I didn't apply my own thermal compund because it comes with its own pre-applied... When attempting to attach the heatsink/fan, I accidently rubbed my thumb very lightly across the pre-applied compound... I cleaned off the smudges I left (with rubbing alcohol) around the compound, but figured everything would be fine... so i installed anyway, and booted up...
No boot-up probs, everything great.
However.... I went into BIOS and had the mobo scan the temperature of the CPU, and the results just didn't seem right....
(averaging, cause it kept swaying)
It said 80º C, and something like 170º F.... (maybe higher in F, but i forget...)
After I seen the high temp(high in my opinion), I quickly turned off the comp, took rubbing alcohol to remove the existing thermal compound, and replaced it with my own (artic silver 5). I also added a little more compound than what the Intel fan had applied....
Anywho... I haven't had a chance to try out the new stuff...
Does 80 C seem correct? I mean its 70 F in my home... and I thought I heard ideal temps for CPUs are 30-60 C....
Any ideas/suggestions would be great!
Thx
It has:
Thx
