heatspreaders?
Bradan
why dont they make the heatspreaders on intel and amd chips with copper, it would drop the cpu temp a great deal for what it would cost
that didnt tell me anything. i dont mean the heatsinks. i mean the heat spreader on top of the actual cpu core, they make them out of aluminum but aluminum is only half as good at transferring heat
IHS, not heat spreader...
what your asking for is why dont they use copper on the Integrated HeatSink?
simple: they do.... watch what happens when you lap an AMD 64 processor
hehe... I'm pretty sure there is a reason why those IHS's are the way they are.. the higher clocked A64's can get quite hot, so if they didnt do that right.. i doubt we would see many of them running atm ;)
It's Integrated Heat Spreader, not Integrated Heat Sink.
o ok,
does lapping do that good of a job at lowering temps? zinc coat is for oxidation obviously right? how thins the coat? how much does it effect temps?(thats kind of a rephrase of the first q:o )
