Wii Gift Card hacking
Might want to change what you just said...but if you want to change the LED colors then you're going to have to buy some red LEDs and somehow remove the blue LEDs and then solder the red LEDs in place of the blue ones...I assume that's how you would do it...
I doubt this thread will be around long. Hacking things like this is generally frowned upon here, and most public boards.
youve got the wrong definition of hacking, this is hardware hacking, it literally means hacking up hardware, but has a lot of variations, this is one of them. Generally it would ential forcing or making hardware do things its not originally designed to do.
This thread is fine
dragon
All I saw was "gift card" hacking. As in, some sort of gift card to use to purchase some sort of content.
Thanks, Webster. :)
Yeah, understandable, I had the same reaction at first :) I looked at the link and it's completely fine. As for changing it to red, I think you just need to get some red colored LEDs and replace the ones that are in there. Target would be real smart to offer different colors on their own, possibly red and green at least...
