Using Playstation 2 wheel on computer
Dylan_
banned
Is it possible? I have a PS2 wheel sitting around and have no PS2 so instead of selling I thought i'd see what I can do with it...
Not all do. I've seen some that just had the PS2 controller plug. But as I said in another post, my Formula Force GP works fine on my computer and PS2. They are probably all the same :P
So you used your Playstation 2 plug in your computer? Where is this slot?
You can get gamepads (ps2) to work on the computer, I'd imaging you "might" get the steering wheel to work also.
I'd Google search for the definite answer (if you do not find it here). It never hurts to buy a converter (if found cheap enough) and test it out.
