Update2 : ok 15 inch im set on right now i just need A. find out if i can put a better videocard on a hp and mabe a better screen if requested or ? buy a video card after and replace it ? or choise
B. find a new laptop and customize it( currently looking through a few that Brant gave me) i would like to avoid dell if possible so anything else at a good price with good quality let me know
Also wanna know how harddrive's differ right now here's what i know
i need :
Widescreen
nvidia 7600 + video car
1 gig + memory
best screen available for company
* dual core 2 processor(2.0 im thinking)<--- ? fastest = good ? or will a lower one due
* ~ Hard drive ~ <--- No idea what i need... it ranges from 40-200 and people dont usally get 200 so im wondering what is sufficient ? is 200 really needed
Cd burner mabe a double layer is a +
webcam,mic, and nice chassy are a +
anything else you can add ?
lmk what you guys think ill be playing starcraft and mabe some warcraft but i wanna be able to play first person games if i feel the urge?
thnx for any help you guys can give
http://www.rockdirect.com/notebooks.php <---- american price's ? ( notebooks with raid
http://www.shopping.hp.com/webapp/s...e&v1=Entertainment&series_name=dv6000t_series
15.4'' Hp Laptop dv6000t
Intel(R) Core(TM) 2 Duo processor T7200 (2.0 GHz)
15.4" WXGA BrightView Widescreen (1280x800)
256MB NVIDIA(R) GeForce(R) Go 7400
HP Imprint Finish + Microphone + Webcam
1024MB DDR2 System Memory (2 Dimm)
160GB 5400RPM SATA Hard Drive
LightScribe Super Multi 8X DVD+/-RW w/Double Layer
Around 1300$$
OR
http://www.xoticpc.com/web/images/3295.htm
FORCE 3295 ( COMPAL HEL80
15.4" WSXGA "Matte" Screen (1680x1050) HEL80 ( + 90 )
Arctic Silver 5 Thermal Compound ( + 37 )
-Intel Core 2 DUO 2.0GHz (T7200) Processor (Merom / 4 MB L2 Cache / 667 FSB) ( + 106 )
256MB PCI-Express nVidia GeForce GO 7600
- 1,024MB (1 SODIMM) ~ CORSAIR ~ DDR2 667MHz Memory ( + 85 )
- Combo Dual Layer SuperMulti 8X DVDRW Drive w/ Software ( + 25 )
- 160GB SATA 150 5400RPM Hard Drive ( + 115 )
Built in 1.3Megapixel Camera
Internal 4-in-1 Card Reader (SD/MMC/MS/MS PRO)
Sound Blaster Compatible 3D Audio - Included
10/100/1000 Network Card & 56K RJ11 Phone Modem
Integrated Fingerprint Reader
around 1500$
OR
http://www.dell.com/content/products/productdetails.aspx/inspn_1501?c=us&cs=19&l=en&s=dhs
E105 insperson Dell
Intel® Core™ 2 Duo T7200 (2.00GHz, 4MB L2 Cache, 667MHz FSB)
15.4 inch UltraSharp™ Wide Screen SXGA+ Display with TrueLife™
1GB Shared Dual Channel DDR2 SDRAM at 533MHz, 2 Dimm
160GB 5400 RPM SATA Hard Drive [Included in Price]
8X CD/DVD Burner (DVD+/-RW) with double-layer DVD+R write capability
256MB ATI MOBILITY™ RADEON® X1400 HyperMemory™
OR
http://reviews.cnet.com/Sony_VAIO_VGN_FS570/4660-3121_7-6240065.html?tag=vid ( gives you an idea what it look's like... but is not the exact same laptop)
Sony VGN-FE790
15.4" WXGA TFT with XBRITE-HiColor Technology and MOTION EYE Camera
NVIDIA GeForce Go 7600
Intel Core 2 Duo Processor T7200 / ICD 2.0 GHz
1 GB DDR-SDRAM (DDR2-533, 1 GBx1) Windows Vista Premium Ready
160 GB Hard Disk Drive
DVD+-R DL_DVD+-RW_DVD-RAM Drive
OR
Gateway® NX570X
Intel® Core™ 2 Duo Processor T7200 (2.00 GHz, 667MHz FSB, 4MB L2 Cache)
1024MB 667MHz DDR2 SDRAM (1-1024MB module)
15.4" WSXGA+ TFT Active Matrix (1400 x 1050 max. resolution)
160GB 5400rpm Serial ATA hard drive
Integrated 8x Multi-Format Double Layer DVD Writer (DVD±R/±RW/CD-RW)
Integrated Intel Graphics Media Accelerator 950
Around 1400$
they all have the same : Memory
Processor Harddrive
_________________1_______________________2_________3
I'd say i like (sony,force,and Hp) the most then dell then gateway? sound about right ? if i get the Hp i will be looking into a better videocard/screen
lemme know if i should just take out one or two of the choise's because they are clearly worse and any opinion's are helpfull as long as they have fast/reason behind them
_________________Likes_______________________Dislikes
Sony:__Screen+good quality_______________more expensive
Hp:__Clean Look+cheap for whats in it_____little worse video card /screen mabe ?
Gateway:_ehhh_________________________bad video card
Dell:___cheap+ same features as others______Bad dell experience's
Force:__extra features( see above)________ big bulky looking( see pics)+ more expensive
i need :
Widescreen
1 gig + memory
Around 1300$$
OR
around 1500$
OR
E105 insperson Dell
OR
Sony VGN-FE790
OR
Gateway® NX570X
Around 1400$
Processor Harddrive
