Laptop?
lb562high
banned
Very much considering buying a laptop, mostly for GAMING, for around the $1000 mark...a little over the budget is no big deal...needs to come with evrything and be ready to go. please post any suggestions b/c im not really an expert on laptops....THNX SO MUCH!!!! :) :) :)
[-0MEGA-];531931 said:
thats actually a pretty good deal, but I would try to find a larger screen.
Ya the screen is the worst thing on it. It would be ok for hooking up to an external monitor but then it wouldn't be portable. What games do you plan on playing?
i plan on playing EVERY SINGLE FREAKIN GAME EVER CREATED!!!!!!!!!!! jk the usuaul CSS, half life 2, COD2, FEAR, etc....
can u guys suggest any other laptops then?
* CPU: Core Duo T2400
* LCD Size & Resolution: 15.4" WXGA (1280 x 800) Glossy
* MB Chipset: Intel 945PM
* Optical Drive: 8x DVD-RW Dual Layer
* Memory: DDR2 1024MB x 1
* VGA Card: nVidia 7600 512MB
* Hard Drive: 100GB 5400RPM
* w/LAN/Fax Modem: 10/100/1000, Fax Modem
* Battery/Run Time: Li-ion 6-cell/4 hrs
* USB/1394/IrDA/S-Video: 4/1/0/1
* Bluetooth: NO
* Card Reader/PCMCIA: 4-in-1/ Express Card
* Color/Weight/Height: Grey/6.5lbs/1.1 ~ 1.6"
* Operating System: XP Home
* Special Features:
Color Shine
1.3 MegaPixel Camera
Audio DJ
Touch Pad Lock
Power 4 Gear+
Battery Re-Callibration
(for those who dont wanna click on the link.)
that looks pretty good, the hardrive is a little on the slower end.. see idealy i would sacrafice space for speed. Other than that it looks pretty good.
pretty cheap? found one @ dell.com for about $1700...can i find it any cheaper anywhere else!!!!!!!!!?
I just build an Inspiron E1705 with:
Core 2 Duo 2.0Ghz
XP MCE w/ Vista Upgrade
17" WXGA+ LCD
1GB DDR2-533
120GB 5400RPM SATA HD
DVD+/-RW Burner
7900GS 256MB
9-Cell Battery
All that for only $1,409.
Core 2 Duo 2.0Ghz
17" WXGA+ LCD
1GB DDR2-533
DVD+/-RW Burner
7900GS 256MB
9-Cell Battery
oh...well thats still kinda over my limit...i dont wanna go over $1200. but thnx anyways.
