how about this one: http://www.newegg.com/Product/Product.asp?Item=N82E16834220104
any good? please gimme suggestions. THNX!
[-0MEGA-];531931 said:thats actually a pretty good deal, but I would try to find a larger screen.
Ya the screen is the worst thing on it. It would be ok for hooking up to an external monitor but then it wouldn't be portable. What games do you plan on playing?
Video Memory - 128MB
Video Memory Type - Shared
(for those who dont wanna click on the link.)* CPU: Core Duo T2400
* LCD Size & Resolution: 15.4" WXGA (1280 x 800) Glossy
* MB Chipset: Intel 945PM
* Optical Drive: 8x DVD-RW Dual Layer
* Memory: DDR2 1024MB x 1
* VGA Card: nVidia 7600 512MB
* Hard Drive: 100GB 5400RPM
* w/LAN/Fax Modem: 10/100/1000, Fax Modem
* Battery/Run Time: Li-ion 6-cell/4 hrs
* USB/1394/IrDA/S-Video: 4/1/0/1
* Bluetooth: NO
* Card Reader/PCMCIA: 4-in-1/ Express Card
* Color/Weight/Height: Grey/6.5lbs/1.1 ~ 1.6"
* Operating System: XP Home
* Special Features:
Color Shine
1.3 MegaPixel Camera
Audio DJ
Touch Pad Lock
Power 4 Gear+
Battery Re-Callibration
pretty cheap? found one @ dell.com for about $1700...can i find it any cheaper anywhere else!!!!!!!!!?
[-0MEGA-];532022 said:I just build an Inspiron E1705 with:
Core 2 Duo 2.0Ghz
XP MCE w/ Vista Upgrade
17" WXGA+ LCD
1GB DDR2-533
120GB 5400RPM SATA HD
DVD+/-RW Burner
7900GS 256MB
9-Cell Battery
All that for only $1,409.
yeah..ill think about it if no one else can suggest any other ones, but the screen size is kinda small........
oh...well thats still kinda over my limit...i dont wanna go over $1200. but thnx anyways.
