staplerz
I have decided to build a computer and i have researched and read all the "101" posts on this forum. I have final after a few days came up with all the parts i need to build my computer but i don't want to buy all the parts just to find out none of them are compatible or are crap. so here is a list of all the parts i have picked out. I am up for any suggestions about my system and any recommendations. I will be using this computer for mainly gaming(high quality settings
) and occasional photoshoping. Also i have exactly $1100 and with that i need to buy a good computer and a 19" or 20" monitor. I already am thinking of a monitor that is $200. any suggestions?
so here it is
Is this a good rig?
1. Will my Hard Drive and RAM work with my motherboard?
2. Will my onboard sound card be good quality or should i buy a cheap sound card(I don't have speakers and I'm using iCEMAT headphones)?
so here it is
- XION Ultimate Engineering XON-002 Black/Silver SECC Steel ATX Mid Tower Computer Case 450 Watt (P4 & AMD Ready) Power Supply -~- $65.00
- ASUS P5B-E LGA 775 Intel P965 Express ATX Intel Motherboard -~- 151.00
- Intel Core 2 Duo E6300 Conroe 1.86GHz 2M shared L2 Cache LGA 775 Processor -~- $192.00
- * Arctic Silver 5 Thermal Compound -~- $6.00
- XFX PVT71GUQF3 GeForce 7900GT 256MB 256-bit GDDR3 PCI Express x16 Video Card -~- $200.00
- OCZ Gold 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory -~- $229.00
- XCLIO GOODPOWER 500W ATX 500W Power Supply 115/230 V UL, CUL, TUV, CB, VDE, FIMKO, DEMKO, NEMKO, SEMKO -~- $52.00
- SAMSUNG SpinPoint T Series HD160HJ 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive -~- $55.00
- LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM IDE DVD Burner -~- $33.00
Is this a good rig?
Thank You For Reading My Post.
I Really Appreciate it!!
