___Xavier23___
When I start up my computer I get a blue error screen saying exactly this...
"*** STOP : 0x0000007B (0x853AD030 , 0xC0000032 , 0x00000000 ,
0x00000000)
INACCESSIBLE_BOOT_DEVICE
If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps:
Check for viruses on your computer. Remove any newly installed hard drives or hard drive controllers. Check your hard drive to make sure it is properly configured and terminated. Run CHKDSK /F to check for hard drive corruption, and then restart your computer.
Refer to your Getting Started Manual for more information on troubleshooting Stop errors."
This happend right after accidentally unpluggin my computer from the power. I forget if the computer was on or not, but I think it was on. Anyways, I tried restaring but nothing, and to shut it down after I have to use the power switch on the back of the tower. I have Windows 2000 Pro.
Please Help
Thanks
0x00000000)
Please Help
Thanks
