Good Barebone?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2848310&Sku=A455-2129 C
anyone have any input if this would be a good start for a middle of the road gaming pc? would you reccomend a different power supply?
It would depend on the video card, but you should be fine with anything that's 'middle of the road'. Even the lower end Ultra V-Series units aren't that bad. Here's another option if you want to choose your own case & PSU:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2851762&CatId=2020
And you forgot RAM :)
jamestheg, while that Hiper PSU looks good, you're paying a lot for those looks. Its performance is only average. Choose a GPU, and look for a PSU from there.
also with that build would running two 7600gt in sli be possible? and is this an easy combination to oc to lets say 2.4 or so
