Nope, I wasn't being sarcastic... It'd be in his sig if he had one wouldn't it.
Yeah i agree.
Maybe he still has xp instaled on his system alongside Vista and just has a realy good Mac osx theme instaled on his xp install;)
I'm still waiting for Vista to arrive in the mail. Free upgrade with my laptop, woo! Base 32bit Home Edition...but Vista is Vista to me.
Didn't you just put XP back on your machine? You're lucky! I don't think my computer will run Vista, maybe when I get my E6600 :D
Well yah, I re-installed/reformatted my entire harddrive.
But I'll just partition and try out Vista when it comes. Hopefully it's useful, otherwise it'll be collecting dust!
I remember seeing a thread were you had a problem, I didn't have a clue how to help though...:confused:
It does look good, I had a play around with it in a PC shop yesterday and it was very smooth, eveything was very nice to look at.
it uses hardly any. its not noticable
Oh right, Cool!
I just tried it, it looks a bit wierd though when you have it on and you have a window open and you can see a bit of your desktop...:cool:
Yeah i agree.
I seriously doubt it, even my os x theme wasn't exactly right. Either he has a mac and pc, or he put the finder bar in with an image editing program...orrr, someone knows how to make a really nice theme.
Is Kubuntu worth it to use? Do you like it more than xp?
Well it depends realy....even though i find Linux to be more relaible and stable i keep going back to windows because i game alot...i still have alot to learn about linux...ive just been instaling some more applications & stuff using the Adept installer.:)
I know you can play some windows game on linux but i just cant be bothred sorting it out...and i heard that most of the games i play anyway do not work on linux whatsoever.
Where did you find that background?
http://www.deviantart.com/deviation/20203561/?qo=5&q=by:swazen&qh=sort:time+-in:scraps
He has a widescreen version too if you look in his gallery.
Rambo, you have Vista and you're making it look like a Mac, Crazy! :P
Errr, no.
I hope you're being sarcastic...Because looks to me like he has a Mac and PC.
Bingo.
Errr, maybe. But I don't exactly own it as such. I also don't put every computer I use in my signature. Otherwise it would be too big.
Yeah i agree.
Nope.
try this:
right click the desktop and go to properties,
then appearance and then effects... mess around in there and see if it helps :)
Damn it! :D
P.S. Nice Mac :P
Thanks.
that didnt help. grr. this is kinda frustrating.
Ok, this is off the top of my head. But, press Windows Key + Pause/Break (or right click My Computer, click properties). Then click on Hardware tab, and and performance. There should be a load of boxes for you to tick near the bottom of the window. One of them is icon shadowing.
P.S. Google always helps too... ;)
