R Rostitute New Member Feb 20, 2007 #1 I am posting this here as the Over Clocking forum is closed, I was just wondering does over clocking damage your equipment after a while?
ETSA New Member Feb 20, 2007 #2 Not even proper measures are taken to reduce heat and limit voltage. If a person understand what they are doing as well.
jedijeff123 New Member Feb 20, 2007 #3 it can, but if u overclock with good cooling and a good mobo, u should be fine. u also need to noe when to stp pushing it. read overclocking 101 for details.
hermeslyre VIP Member Feb 20, 2007 #4 Yes.. voltage and stability are the main cause of premature death. Don't push the voltage to far and test your stability with programs like prime95. Edit: A constant overclock won't reduce life expectancy too much.. it might take a year or two off a 10 year lifespan. Last edited: Feb 20, 2007
ETSA New Member Feb 20, 2007 #5 It will be outdated before it explodes in a flaming fireball of death inadvertently triggering armageddon.
jedijeff123 New Member Feb 20, 2007 #6 ETSA said: It will be outdated before it explodes in a flaming fireball of death inadvertently triggering armageddon. Click to expand... that would be something i would like to see.....lol
gottabamd New Member Feb 22, 2007 #7 voltage is what kills equipment. if you dont raise the voltage it shouldnt damage it any more than normal.
