ok, thanks. ill try to see if i can kan build one myself. But out of the two i computers i posted before, which one is better suited for gaming?
Between the two you chose from...????
Motherboard: Biostar TForce 945P motherboard Core 2 Duo Support
(PCI-E, FSB1066MHz, Intel 945 chipset)
CPU køler: ThermalTake Socket 775 Xtreme køler
Ram: Original 2 GB DDRII-667 PC5400 RAM DualChannel
Harddisk: Maxtor 320GB harddisk S-ATAII 3Gb/s Fluid
Grafik: Nvidia GeForce FX7600GS 512MB PCI-E Grafikkort
Kabinet: Bogart Miditower Deluxe LowNoise med håndtag
Strømforsyning Bogart 400W ATX strømforsyning Silent med 80mm køler
Lyd: 6 kanals audio codec RealTek (SoundBlaster komp.)
Drev: NEC 5170 DVD-brænder +/- Dual layer
Netkort: 100/1000 Mb/s Realtek GIGABIT, Supports ACPI Power Management
Software: Alle drivere m.v. medfølger. Windows Vista KLAR
Service: Vision ServicePack
Although, I wouldn't go with a BioStar motherboard, something else because of drivers and issues of flashing the BIOS and all. But, the Nvidia choice is better than the ATi - After all, ATi was bought out! AMD now owns them!
Good luck!
