Need new computer for gaming, Please help
i have though abou thisone, is it any good?
PACKARD BELL COMPUTER IXTREME 9415
Intel Core 2 Duo E4300 processor (1.8 GHz)
640 GB SATA harddisk (2 x 320 GB)
2048 MB DDR2 RAM (2 x 1024 MB)
DVD-R/-RW/+R/+RW/+DL
10/100 Mbit netkort
ATI Radeon X1650SE grafikkort med 1024 MB Hypermemory
8-i-1 hukommelseskortlæser
Tastetur med aflæsning af fingeraftryk
Microsoft Windows Vista Home Premium medfølger
or this one.
Motherboard: Biostar TForce 945P motherboard Core 2 Duo Support
(PCI-E, FSB1066MHz, Intel 945 chipset)
CPU køler: ThermalTake Socket 775 Xtreme køler
Ram: Original 2 GB DDRII-667 PC5400 RAM DualChannel
Harddisk: Maxtor 320GB harddisk S-ATAII 3Gb/s Fluid
Grafik: Nvidia GeForce FX7600GS 512MB PCI-E Grafikkort
Kabinet: Bogart Miditower Deluxe LowNoise med håndtag
Strømforsyning Bogart 400W ATX strømforsyning Silent med 80mm køler
Lyd: 6 kanals audio codec RealTek (SoundBlaster komp.)
Drev: NEC 5170 DVD-brænder +/- Dual layer
Netkort: 100/1000 Mb/s Realtek GIGABIT, Supports ACPI Power Management
Software: Alle drivere m.v. medfølger. Windows Vista KLAR
Service: Vision ServicePack
which one is better, i any of them are good for gaming
(wow, counterstrike, BF2)
build one if you can, u will get a beast on a budget.
the exact computer in my sig cost me 1030$ CANADIAN it would have costed me over 1800+tax US DOLLARS from alienware or similar company for the same thing. mind you im not using a legit copy of windows, but still, 130 for an vista cd would still be super cheap
10/100 Mbit netkort
or this one.
If you are still looking for a system, let me know. I can help you! It's one of the things I do. I'm a PC reseller - partner for Microsoft and Intel.
Drop me a line, and I can help! Or PM me!
ok, thanks. ill try to see if i can kan build one myself. But out of the two i computers i posted before, which one is better suited for gaming?
Between the two you chose from...????
Although, I wouldn't go with a BioStar motherboard, something else because of drivers and issues of flashing the BIOS and all. But, the Nvidia choice is better than the ATi - After all, ATi was bought out! AMD now owns them!
Good luck!
