Hi,
New to this forum so first i'll say hi. I have a slight problem installing XP Pro and i'm not the brightest when it comes to pc's, heres the problem.
I was originally running windows 2000 on my laptop and decided i wanted to format the hard drive due to the amount of crap on it so I inserted the new xp pro disc and booted up the pc. Pressed a button and entered the setup. Setup then checked files etc.. I then pressed D which deleted the partition that the old OS was on. I then pressed enter to install XP on that partition (even though there wasn't one it still kinda creates one) it then gave me the option to format or format quick. I chose format. It formatted the hard drive and then started. with that done it then said choose partition on which to install, hit enter on the partition and it comes up with please wait while setup copies files to the windows installation folders. after that completes it then restarts the pc. The windows xp loading page comes up and after the blue bar along the bottom passes twice on the 3rd time it just freezes and the pc does nothing! anyone got any ideas what the hell to do?
I know this is real long but i just want everyone to know exactly what i've done so far!
Thanks, any help would be much appreciated.
Simon
Simon
