Difference between Core Duo and Core 2 Duo
xBoom
Which is better, the Core Duo or Core 2 Duo?
And I heard that there are socket 478 version of Core Duo, is that true?
Where did you hear core duo? Link please? and If Core duo is core 2 duo then no they are not on any other socket than LGA 775
"...Socket 478 is officially known by Intel as FC-PGA2. While Core Duo is available in a 478-pin package, that socket is different: micro FC-PGA, which was also used for earlier Pentium M and Celeron M processors..."
It's Wikipedia: http://en.wikipedia.org/wiki/Socket_478 (the last paragraph).
-_-, obviously Core 2 Duo is better, I don't think they sell Core Duos anymore, I can't seem to find them in new computer stores, I think can you only get them second hand.
I have seen some new cheap laptops come with them, i guess they're trying to fool the buyer into think it is a core 2 duo
from what i understand the core 2 duos performance is only 10-15% higher than a similar core duo although i cant remember where i heard this. you can also still buy core duo mobile processors on newegg.com. i hear the core 2 duo mobile processors aren't as power hungry though
I remember seeing them a while ago... they were decently priced and I was going to get one, and then they kinda disappeared.
all laptops are 32-bit thats y theres are 32 and 64 bit edition for new vista os.
No there not, most laptops are 64-Bit.
The only major differences between the Core Duo and Core 2 Duo, is that the Core Duo is only 32-Bit, has a lower FSB, and has less cache then some models.
Core duos weren't as widely used as core 2 duo. It's almost completely used for laptops and are sometimes advertised as "dual centrino". My dad's laptop has a core duo processor.
Core Duo doesn't have slower FSB. Both Core duo and Core 2 duo have 667MHz FSB or 533MHz (depending on the model)
I realized that after looking at CPU-z on my laptop. I was thinking that the Core Duo's had 533 on most of their models.
