Master Mind
hey,
just wondering if any one has had/tried/read about this combination. i have just purchased these and 5 more fans to fill the 9 120mm gaps. im a little bit worried that the heatsink wont fit into the case. the reason is say this is because the heatsink itself is 16cm high while the case is only 25cm wide. i have 9cm to clear the fans on the side panel + the space between the mobo and mobo tray + the thickness of the mobo and cpu together....
Master Mind
Master Mind
