Da Mail Man
win xp pro sp1+2, 300gb sata, 1gb ddr ram....4.0ghz processor..........will a 680 watt power supply be more then enough to run the system with a bit more should i attempt to "expand" it?........thanks!
There is no 4GHz processor, so it's hard to know what your specs really are seeing as some processors can take a good bit more power than others. Regardless, you should have more than enough assuming it's a "good* 680 watt PSU. This means it probably has more than one rail and 30+ amps total on the 12v rail(s)
What 680W power supply, and what video card(s) are you using? It sounds like it should be quite sufficient, though.
