few problems with vista here. in fact, the only problem i have seen so far was half life 2 not being able to load saved games. which might not even be vista related.
as pceye says you'll just need more ram really. but looking at your sig you already have 2gb so you should be fine.
i think the 'vista is bad for gaming' statements are just coming from people not realising that vista needs 512mb ram compaired to XPs 64mb ram. in a pc with only 768 or 1gb of ram, that missing 450mb can make a big difference. less ram available for gaming = slower gaming.
This is kinda off topic but what board is zaroba running that allows for 5 gigs of ram thats a strange number to have plus i have never seen a desktop board with just 5 slots and wtf are you using all 5 gigs for i have 4 and even that is to much i never ever use it all!
What urks me about XP and now the 32bit version of Vista is that no one has found a way around the 4gb limitattion like was done for the 512mb on the older versions like 98.
wow, look at 64bitshe means they got around the 512mb limitation in windows 98. not the 4gb limitation
but yea, its not exactly possible to get around the 32bit 4gb limitation. not unless you somehow reprogram windows to allocate more bits for memory addressing. its limited to 4gb because 32 bits ( 2 to the 32nd power) only equals 4,294,967,296 bytes of addressable memory.
No one has found a way around the 4GB barrier because it's NOT POSSIBLE. Those are 32 bit operating systems, run on 32 bit processors.
