I am using an acer EM61/SM motherboard with nvidia 6100V chipset. my processor is AMD athlon 64X2 at 2.2 GHz and I have 4X1 GB DDR2-800 memory sticks installed but they are only running at 400 MHz. I checked under PC wizard, it shows that the chipset memory type is DDR2-400....does that mean the best memory this motherboard will support is DDR2 400 or it can be reset to DDR2-800? It also shows that the DRAM/FSB ratio is CPU/11...Thanks
