New Computer Build
shawy14
Please will you read down the following componants and tell me what you think about them. The computer is intended for gaming and multitasking. I dont have much to spend so I did my best to get the best parts.
CPU - AMD Athlon 64 X2 5200+
Motherboard - Gigabyte M57SLi-S4 Socket AM2
Graphics Card - BFG 8800 GTS 320Mb Graphics Card
RAM - Kingston ValueRAM - Memory - 2 GB
HDD - Seagate Barracuda 7200.10 - hard drive - 250 GB - SATA-300
Power Supply - Akasa Ultra Quiet 500W PSU with 12cm Fan
The case isnt really important at this time because I know lots of people who specialise in computer cases.
Thank-You in advance
Richard Shaw
my budget
its is around £600 for just the CPU, RAM, Motherboard, Graphics Card and PSU. I have everything else. Thank-you
You will get far better performance with an e4300 and it will be cheaper and easier to overclock. Use any money you have left over to get some better RAM.
Intel Core 2 Duo E6600 Conroe 2.4GHz - $225USD
Patriot eXtreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail - $129.99 (AR) - $130 (AR)
GIGABYTE GA-965P-DS3 - $130
EVGA 8800GTX - $560
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply - $129.99
Total: $1175USD or just under £600.
Good luck.
EVGA 8800GTX - $560
Good luck.
https://secure.scan.co.uk/Shop/ViewCart.ASP?SessionCheck=898041699 please look at these. I decided i need a SATA HDD to so i added one in. I wished i lived in america. Computer parts sooo cheap lol. thanks :D
