powerful computer...help
alexisahn
okay so i made these specs a couple months ago.
they are still decent, but i'm looking for an even better computer.
right now i'm looking for a dual dual core computer that will not only run photoshop and 3DSM with ease, but also be able to play the latest games.
here's what i came up with a few months ago (not sure if everything is compatible [the ram probably isnt], but it gives an idea of what i was looking for)
156 - XFX PVT71PUDP3 GeForce 7900GS 256MB 256-bit GDDR3 PCI Express x16 EXTREME Video Card
370 - TYAN S2915A2NRF Dual Socket 1207 NVIDIA nForce Professional 3600 + 3050 Extended ATX Server Motherboard
250 - AMD Opteron 2212(WOF) Santa Rosa 2.0GHz 2 x 1MB L2 Cache Socket F Dual Core Processor
666 - Kingston 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) ECC Registered Dual Channel Kit Server Memory Model KVR667D2D4F5K2/4G
50 - COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel, SECC ATX Mid Tower Computer Case
27 - Dynatron A86G 60mm 2 B all CPU Cooler
27 - Dynatron A86G 60mm 2 Ball CPU Cooler
33 - SAMSUNG Black 18X DVD+R 8X DVD+RW 8X DVD+R DL 18X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache IDE DVD Burner With 12X DVD-RAM Write, LightScribe Technology
31 - LG Black 18X DVD+R 8X DVD+RW 8X DVD+R DL 18X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache IDE Super-Multi DVD Burner
floppy drive
powersupply (prolly 1000w)
additional fans
the numbers before each item were the prices when i created the spec. the prices have dropped a bit. for example the graphics cards cost about 140 a piece now with mail in rebate and the motherboard costs 305.
if anyone has a spec that would maximize my money (2k-3k) with all the recent products, then i'd be grateful to know. i'm not sure what's the best thing to buy right now (especially with the high prices on the quadcores and such). any dream computer specs anyone has with a budget between 2k and 3k?
A single Core 2 QX6700 would be better but the best on the market before overclocking is 2 74-FXs but theyre bloody expensive, any I'd get a single 8800GTX or dual 8800GTS but 2 8800GTX would be awesome if you could get it,
how bout this, tell be your budget and ill so you a much better Computer
Core 2 Extreme QX6700($530 on July 22nd, $1000 now)
EVGA 680i SLI Motherboard($250)
EVGA 8800GTX($600)
Corsair 620 watt power supply($160)
4 Gb(4x1) of Corsair XMS2 DDR2-800($240)
2 Sata DVD Burners($80)
150 Gb WD Raptor HDD($200) and 500Gb HDD($115)
Antec P180B Case($130)
$2300 on July 22nd or $2800 now
The 4 Gb of ram 4 cores and 10k RPM HDD will make it nice for rendering and the 8800GTX can run any current game max.
Board: EVGA 122-CK-NF68-T1 680i SLI - $230
Memory: CORSAIR Dominator 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) - $204-$44 rebate - $164
CPU: QX6700 - $968
Cooling: Scythe SCINF-1000 120mm CPU Cooler - Retail - $58
Video Card: EVGA GeForce 8800GTX 768MB KO ACS3 - $650
Sound Card: Creative Sound Blaster X-Fi XtremeGamer 7.1 - $90
Power: CORSAIR CMPSU-620HX $170-$20 rebate - $150
HD1: 150GB Raptor $210-$30 rebate - $180
HD2: 320GB WD - $77
Floppy/Flash: uh? none
CD: Pioneer 18X DVD±R - $32
Chassis: Thermaltake Swing, Clear Side Panel - $69
Monitor: LG L226WTX-BF Black 22" 5ms DVI Widescreen LCD Monitor 300 cd/m2 3000:1 - $350
Speaker: Creative Inspire P7800 90 Watts 7.1 Speaker - Retail - $77
Mouse & Key: Logitech G5 Mouse + Logitech Media Elite - 46+25 - $71
Total: $3166 now or ~$2728 on July 22nd after the CPU price drop. 22inch monitor included.
first time builder, my budget is between 2k-3k. i think two fx-57's might be possible...considering they cost about 450 a piece.
CPU: QX6700 - $968
HD2: 320GB WD - $77
I think you should go for 700W PSU... Just my opinion becuase your comp looks like a gamers build :D
Two fx-57 don't have anything on a QX6700. Hell, two fx-74s don;t have anything on it.
Two 74s are better than 1 QX6700 in most multi-threading apps I'd get one if the mobos weren't 500 bucks (I agree with you on the 57s through... there terrible)
oh sorry, mean two fx 74's not 57's aha.
just been really tired recently. i get things mixed up.
so wait, one quad core is better than two fx 74s?
In certain situations they better each other. However the Core 2 Quad has the advantage of only having to communicate between the two dies whereas the AMD FX series have to communicate via the motherboard.
The FX74s are worse because there are not going to be many more processors for the AMD socket used for 4x4, they consume 75% more power and the motherboards are alot more expensive
so here's a new setup...
and the motherboard wasnt that expensive (330 vs probably around 250-310 for an intel quadcore motherboard). the qx6700 is 980 dollars anyway...and the fx-74s are only 410.
$329.99 - ASUS L1N64-SLI WS Dual Socket L (Socket 1207FX) NVIDIA nForce 680a SLI MCP SSI CEB AMD Motherboard - Retail
$409.99 - AMD Athlon 64 FX-74 Windsor 3.0GHz 2 x 1MB L2 Cache Socket F (1207 FX) DSDC Architecture Processor - Retail
$649.99 - EVGA 768-P2-N837-AR GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 KO HDCP Video Card - Retail
$229.99 - G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
$209.99 ($179.99 after $30.00 Mail-in-Rebate) - Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
$349.99 ($199.99 after $150.00 Mail-In Rebate) COOLMAX CTG-1000 ATX12V 1000W Power Supply 100~132VAC or 200~264VAC - Retail
$89.99 - Creative Sound Blaster X-Fi XtremeGamer 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - Retail
$49.99 - COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel, SECC ATX Mid Tower Computer Case - Retail
total so far: $3120
with rebates: $2900
some of the stuff is retail (motherboard, cpus, etc) so the price may be able to be trimmed a bit more. the pricedrop could also give me some extra cash. but i think thats for intel only...
i'm going to need a bit more cash for the dvddrives and cooling devices. i heard QFX get pretty hot. i'm not sure about the graphics card....650 is a big chunk of my budget. wouldnt it be better to just get two and run them in SLI mode?
any suggestions on my current setup would be nice. i dont want to get the intel quadcore because i think it will lose its edge in the future. ANY improvements would be nice (like price vs effectiveness). any problems in compatibility would also be appreciated.
