$2000 budget, need your help please
apatel9
Can Someone please make me a build for about $2000, I dont need a PSU or Case (have antec treo 650watt and antec P180 case). It will be used for gaming /multitasking. Any help will help, I want to order this computer this week (I know that there is a price cut comming at the end on july but im kind of in a rush). Thanks
qx6800
8800gtx
2gb ddr800
still have room for any mobo of choice :) still under 2000.
You cant do that for $2000. Maybe with an 8800GTS 320MB, cheap HD, cheap case, and cheap PSU, but not if you want a great system overall.
I would build something similar to mine, except get an E6600, and upgrade to an 8800GTX.
he said he didnt need case and psu :) thats why i didnt suggest 2 gtx
lol, shows what happens when I just read the title :P
I guess that build is possible, but still, the QX6700 eats up half your budget, then add in a GTX and you only have $475 for a hard drive, RAM, sound card, motherboard, accessories, and if he needs a monitor, keyboard, mouse, OS, that all adds up :)
[-0MEGA-];677047 said:
But if you read the reviews, I believe those are so cheap because there was a design flaw with them, and how they dont support quad-cores very well.
Then why is it being paired with a q6600?
I had something like this in mind...
Q6600-$540
2gigs DDR1066-$200
8800GTS 640 (i only have a 19inch monitor so the gtx might be overkill)-$400
680i motherbord $260
cooling fan-$60
DvD burner $40
Harddrive-$100
wirless card-(not too sure about price)\
windows vista 64bit-$200
this is about $1800 plus tax and shipping, so it should be around $2000
what do you guys think?
Q6600-$540
2gigs DDR1066-$200
cooling fan-$60
DvD burner $40
Harddrive-$100
You'll be sorry, since by july 22 you could get the QX6700 for the same price
gigabyte ds3 mobo
e6400 processor
8800 gtx
hitachi 7k1000 HDD
2gb of any ddr2 pc8000 memory you can find
A cheap used dvd drive
Should come in around $1700 if you order from newegg and are willing to wait a week
just went and checked newegg:
HITACHI Deskstar 7K1000 HDS721010KLA330 (0A34915) 1TB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822145141
Return Policy: Limited 30-Day Return Policy
$399.99
BFG Tech BFGR88768GTXOCWCE GeForce 8800GTX 768MB GDDR3 PCI Express x16 Water Cooled Edition HDCP Video Card - Retail
Item #: N82E16814143085
$939.99
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory Model F2-8000PHU2-2GBHZ - Retail
Item #: N82E16820231077
Return Policy: Standard Return Policy
$199.99
GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
Item #: N82E16813128012
$129.99
Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775 Processor Model BX80557E6400 - Retail
Item #: N82E16819115004
Return Policy: Processors (CPUs) Return Policy
$187.00
Subtotal: $1,856.96
