Building a Gaming Computer, Parts listed, need help/opinions/advice!!!
OmegaZer0180
Hi all, this is my first time building a new computer from scratch and I was wondering if i could get some advice,opinions, or comments. I have a list of the parts that I am going to order, but I want to make sure that it's all compatible and okay.
all from newegg
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/product/product.asp?item=N82E16811129021
ASUS M2R32-MVP Socket AM2 AMD 580X CrossFire ATX AMD Motherboard
http://www.newegg.com/product/product.asp?item=N82E16813131095
EVGA 256-P2-N755-TR GeForce 8600GT 256MB 128-bit GDDR3 PCI Express x16 Superclocked Video Card
http://www.newegg.com/product/product.asp?item=N82E16814130091
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply 100 - 240 V UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick
http://www.newegg.com/product/product.asp?item=N82E16817139001
AMD Athlon 64 X2 5200+ Windsor 2.6GHz 2 x 1MB L2 Cache Socket AM2 Processor
http://www.newegg.com/product/product.asp?item=N82E16819103759
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/product/product.asp?item=N82E16820231065
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/product/product.asp?item=N82E16822144701
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Burner
http://www.newegg.com/product/product.asp?item=N82E16827106057
Ok those are all the parts. I was wondering if everything is fine with this current setup? My biggest worry is that something is not compatible with something else (IE, somethings requiring more voltage than my power supply can output or something.. I dunno, I'm a newbie.)
My other question is, once I get everything put together, will I have to spend considerable amount of time configuring the BIOS? or will it be pretty much all set to go when it's set up? I'm not too familiar with doing anything in BIOS so i would have to get a friend to help me if I needed to tamper with it.. But basically after I put it together it's just installing the drivers and operating system right?
As for the operating system...
I have both XP professional and Vista Ultimate and I'm not sure which one to go with. I've heard that some applications will not work properly with Vista, so I'm kinda hesitant about it.
Basically I want to be able to run FPS games like vegas, supreme commander, starcraft II (when it comes out) and cs source. Thanks in advance!
Go with an AMD setup, i hate intel...and AMD is better :P
If you go with AMD get the 5600 for $10 more and if you plan on overclocking go with intel...a little more pricey though
I'm trying to keep my budget around 800-900 dollars.. the current setup is about 950 but that's as much as i'll stretch it. Price is pretty much why I chose AMD over intel..
Skim on the case a bit and the motherboard and go with C2D if it's the price that's killing you. The motherboard you have now has crossfire capability, but if $$ is scarce I don't think you will be using that capapbility anytime soon so no need for it, right?
Your current mobo and cpu run at $300
For the same price you can get this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003 and http://www.newegg.com/Product/Product.aspx?Item=N82E16813131041
As far as BIOS goes, you really shouldn't have to mess with them unless you plan on OCing? In which case, from what I've heard but please don't quote me on this, Intel is better at the moment.
Wait until July 22nd...you can get the e6600 for about the same price as the AMD. You could probably make some more money by then to get better stuff.
July 22nd is too long of a wait! lol'
I've changed my parts list around, now it's quite different. Tell me what you guys think. I've added a monitor, keyboard, mouse, and speakers to get the entire desktop.
-Same case
-GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express ATX Intel Motherboard
http://www.newegg.com/product/product.asp?item=N82E16813128012
-EVGA 320-P2-N811-AR GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Video Card
http://www.newegg.com/product/product.asp?item=N82E16814130082
-XCLIO GOODPOWER 500W ATX 500W Power Supply 115/230 V UL, CUL, TUV, CB, VDE, FIMKO, DEMKO, NEMKO, SEMKO
http://www.newegg.com/product/product.asp?item=N82E16817189005
-Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor
http://www.newegg.com/product/product.asp?item=N82E16819115003
-same ram
-same harddrive
-same dvd burner
-microsoft ergonomic keyboard + mouse 21.99
http://www.newegg.com/product/product.asp?item=N82E16823109156
-samsung 19 inch lcd vista ready
http://www.newegg.com/product/product.asp?item=N82E16824001088
-speakers 23.99
http://www.newegg.com/product/product.asp?item=N82E16836157002
The total now is around 1200, a little high for what I hoped for, but for the entire desktop it's do-able. It would have been more ideal around 1000, but 1200 is the lowest I could get it.
I decided to go for the 8800 as many people have told me, I think it would last me longer and be better for me in the long run. And I switched over to the e6600 as well.
And for the question of using XP or Vista no one has answered yet. Should I just install XP pro first until I feel the need to upgrade to Vista? or should I just go ahead and install vista over XP? Are the problems with Vista and it not being able to run some applications true?
Thanks all.
Dude people may argue with me but... If you stick with AMD and an AM2 mobo. you can get a phenom proc witch is supposed to knock the crap out of intel. And it prolly will. But at the moment yes intel is better!
Somebody suggested me the 7900GS or the X1900GT..
would those work for me? I know they are dx9 cards, will i have to upgrade to dx10 in the future? The only reason i would see the need upgrading would be to run vista.. and if that was the only reason, i'll just stick with XP
Do you have any proof than Phenom is going to knock the crap out of intel ?
You need to compare Phenom to Penryn, not Conroe.
Because Penryn will come out on Q4 2007 and it will compete with AMD Phenom.
