sniperchang
Hey, I was just curious to know if there were any programs that allows better file transfers over a network than using the usual file sharing with explorer.
Say I want to transfer a big file; with explorer, all you get is a small box estimating how much time it takes and you can't pause it if it takes to long.
But would there be a program that does the same thing, but it displays the %, the speed, etc. and have the ability to pause the transfer, and/or verify the copy when the transfer is done?
Oh and maybe have the ability to make a sharing folder (or something similar) which copies the contents on both (or more) computers either automatically or periodically
Thanks!
Thanks!
