INTELCRAZY
banned
Okay, after running Darik's Boot and Nuke, I can't boot the Windows XP CD. WTF!? Help?
Thanks
Thanks
you seem to be having problems everyday![]()
The problem is you wrote all 1's and 0's to your computer does bios see the cdrom? If it does thats a start you can set it to boot from cd and nothing else to see if that helps any.
I have it set to boot from the CD-rom first, BIOS sees both but only one drive works out of Windows. I still get this msg. If this has kept it from reading my optical drives, why would they make programs like this when they know we are reinstalling an OS? How do I get it to boot from the Windows XP CD?
Also see if there is a boot menu (like hit F9 for boot menu) at start up.
are you pressing any key when it asks to boot from the CD....? Also see if there is a boot menu (like hit F9 for boot menu) at start up.
