please help select my pc
isaacual69
hello all...i am currently looking to build a new computer, which will be used for primarily audio and video conversion, as well as some light gaming with racing games being the focus. i will need a complete system, including lcd and a descent case as well as wireless keyboard and mouse (but not nessecary)...my budget is $650, maxed at $700 including shipping costs...i am in michigan as well...i know its a tight budget, but lets see what the computer forum brings me...thanks for the replies
how about this:
Intel Core 2 Duo E4300 Allendale 1.8GHz LGA 775 Processor
http://www.newegg.com/Product/Product.asp?item=N82E16819115013R
$104.30
MSI P4M900M2-L LGA 775 VIA P4M900 Micro ATX Intel Motherboard -
http://www.newegg.com/Product/Product.asp?item=N82E16813130093
$48.99
Kingston 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Dual
http://www.newegg.com/Product/Product.asp?item=N82E16820134046
$64.99
XFX PVT73GUGF3 GeForce 7600GT 256MB GDDR3 PCI Express x16 Video
http://www.newegg.com/Product/Product.asp?item=N82E16814150185
$119.99
Western Digital Caviar SE WD2500JS 250GB 7200 RPM SATA 3.0Gb/s Hard drive
http://www.newegg.com/Product/Product.asp?item=N82E16822144417
$66.99
Sony NEC Optiarc 18X DVD±R DVD Burner With 12X DVD-RAM Write Black
http://www.newegg.com/Product/Product.asp?item=N82E16827152076
$29.99
Thermaltake SOPRANO VB1000BWS Black 0.8 mm SECC Chassis, Plastic Front Door ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16811133145
$79.99
Now im pretty sure thats a good build and all compatiable with each other and would be ok for what you want to use it for.
ive missed ot a Psu because i dont know what ones are good lol.
the total of that build so far is
$515.24
so you would have some left for the Psu etc i think :)
how about this:
$104.30
$48.99
$64.99
$119.99
$66.99
$29.99
$79.99
$515.24
That is a nice build, as for a PSU, I would recommend this. Maybe he should go with a full ATX board though, I like your build Nevakonaza, I might change a few things though.
PSU
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2974307&CatId=1079
What OS are you using?
how about this:
$104.30
$48.99
$64.99
$119.99
$66.99
$29.99
$79.99
$515.24
Plus maybe $50-$75 in shipping... and insurance if needed.
how about this:
$104.30
$48.99
$64.99
$119.99
$66.99
$29.99
$79.99
$515.24
The LCD monitor is going to kill that budget though. But I like that draft build. Very nice.
thanks for all the help. you dont think i should go ith amd instead since their new cpus are coming out soon and i will beable to upgrade to it later with a current am2 board? i will just use the crt for now...good idea, that way i can use all my budget on my pc. if everyone thinks i should do a intel then...alright i guess. i do not need ram though cause i already have 2 gigs of ddr2-667 kingston. and i might go with a different case for maybe a little cheaper, and a different board that is regular atx and has a different chipset other than via (i dont like them). but so far this sounds promising...thank you all again so much and any final thoughts about this thread is welcome
Sorry for 2x posting.. but you didnt include the power supply, cpu cooler, speakers, mouse, keyboard, operating system.
Optional:
Sound card
Case Fans
