Well, i just upgraded from a Sempron 939!! because i didnt have enough budget change all the way to socket AM2. So no, i cant change my CPU any more, would more memory help???
And overall, would a system with a 8600GTS run games better than a 7600GT one????
What do you mean more RAM wouldn't really change much?? More RAM would be an excellent idea, 2 gigs would be good.
Your 7600gt is fine for now.. Save up an extra hundred or so and spring for a 8800gts.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125054
Yeah, I'd say save your money and wait... Also, I think your PSU would run an 8600...
I'm running my rig on an Antec 380watt...
Only has 18amps on the 12v@ rail ...
What i meant is that he won't see that much difference compare to a video card or another component DUH
No, that psu can't power it at all, it probably wouldn't even turn on
I run an 8500 on my PC with a 450watt PSU and it turned on and my CPU is a 3800 X2 with a 939 socket.
