Person1234
Power won't come on motherboard. It's a new board, but for some reason the it won't turn on.
How do I tell if it's shorting out?did you plug in the 4 pin connector if it has one? did you put the on/off button wires on the mobo?did you install the cpu correctly? is the motherboard shorting? is the power supply faulty? is the motherboard bad?
their might be some sparks at times... the motherboard is touching the case. just take the mobo outta the case and set it somewhere (like a desk) connect everything back and thats it,... just dont set it on a metal surface![]()
