g4m3rof1337
How easy is it to upgrade a laptop hard drive?
Thanks
Thanks
Alright.
Thanks.
Whats the biggest hard drive that can be put into a laptop?
The SATA controllers in most newer laptops will support two HDDs, but there is no place to install the 2nd one. Otherwise the only real options for upgrading are memory and a better optical drive. Laptop coolers and a 2nd battery are also a good idea. Wish there were kits to build your own
I'm almost positive you cant put dual HD's in a laptop. Unless you had an external one.
there are kits to build your own laptop. ASUS just released a new one
swaping HDDs is easy, just make sure the interface is the same. adding a new one means youll need a mounting bracket and maybe an adapter. just do your homework and things should be easyHow easy is it to upgrade a laptop hard drive?
Thanks
ever heard of newegg.com?Are they for sale?
Is the biggest 250?
And can I put dual hard drives in?
