dude intel oscaryu is rite its the ram. the ram is faulty somethigns wrong i dont know if your work will allow you to replace the ram but you should look into it. hey intelcrazy you should apply to become a moderator
Volunteer Moderator Applications are open however the following are a general requirement:
1. Must have 1,000+ posts, significant portions of which are not one-liners but actually helpful posts.
2. Must be a member for 120 days (4 months)
3. Demonstrated expertise/understanding in areas relevant to the forum section selected
4. Generally speaking, follows/enforces rules, is helpful etc. A very big factor here is to demonstrate open-mindedness...
If you think you're qualified, please send a private message to Ian
Please nominate the section you would like to moderate and what experience you have in that particular area.
** Generally speaking, we only respond to moderator applications if your application was considered successful. Moderator applications need to be approved by both Administrators Ian and Praetor and successful applicants are notified within about two weeks via pm. No response is sent if your application is not successful.
I mean man you fit all the credentials
been here for four 6 months
almost 3000 post
