From what i have read and seen, the 5600 is better than the 6000+? i hear it uses less power and runs cooler, also if you oc the 5600 it will outperform the 6000+....
I've heard that too. Apparently, once overclocked, the 5600 runs just as hot as the 6000 and the money saved doesn't justify the difference in power consumption. Also, you could just as easily downclock a 6000 to 2.8 GHz and undervolt it, so that power consumption is lower (nerfing it essentially
