INTELCRAZY
banned
Yes, @bios is Gigabytes Windows bios update program. If you want update through the bios you use Q Flash, you just download your new bios and save it to a floppy, boot go into your Bios and pick Q Flash and then put the floppy in with the bios you downloaded
Q Flash
http://www.gigabyte.com.tw/FileList/NewTech/old_motherboard_newtech/flashbios_qflash.pdf
That's simple, is that all, anything that could cause a problem with that? If I do it in BIOS(as above), do I have to do anything else?
Thanks
